This compy is currently a P4 1.4ghz with 192mb RAM running 98 on a 20gb IBM drive.
Initial thought was that the HD was dead - suddenly windows could not be booted, and when you tried to reinstall the OS it said no HD found. Owner did eventually get it to boot, and they got all their important stuff off of it. I brough the machine home later and did a disk-to-disk transfer of their drive, everything worked fine. However, I did notice 6 bulged and leaking YEC 1000uf 6.3v caps clustered right around the IDE connectors.
Replaced those caps and haven't had a hiccup with the old drive yet, even throwing it through extensive tests. I'll be giving the compy back, recapped, tomorrow, with the old HD still running in it to let them give it a shot in production . Here's the pics:
General layout of the board:
Closer of the bad caps:
The board replaced, and half-installed:
I ended up replacing the caps with what I had, 4 were replaced by 1200uf 6.3v Panasonic FM series, and 2 were replaced by 1500uf 6.3v Panasonic FM series. I need to replenish my smaller value cap stock!
And now, to the air compressor!
