macbook pro a1286 no image on internal but ok on external
    Re: macbook pro a1286 no image on internal but ok on external
    I've got the same board A1286 820-2915 with the same problems on the 38,39 & 40 LVDS pins.
    The foil for the pins are blown off the board and require jumpers to diode D9701, problem is, I have the schematic but not the component view file, so I have no idea where diode D9701 is.
    If some one could tell me where to jumper to it would be worth 1000 internet points and make me very happy!
      Boardview available in post #2.
        The schematic is opening, but I'm not getting the board view to open.
        Is it the BRD file? I'm trying to open it with openboardview but it cant.
          Yes it's the .brd file.
          I've just tested on a clean Windows 7 laptop and it opens and views fine.
            What program are you using to open the BRD file?
              I got it to work. Sorry to be such a pest.
              I was trying to drag and drop the file into openboardview. When I manually select file open then it works.
                Drag&Drop should work fine too. Are you using the latest release of OpenBoardView (check below)?
                  thank you
                    Mil gracias por el esquematico
                      Hello, I'm loocking for A1286 mid2009 logic board ref: 661-5212...5214 shematic diagram or board view. Thank's for my old Mac
                        Originally posted by dellxps15 View Post
                        here is schematic + board view.
                        edit: post good picture of lvds connector zone.
                        Thank you so much for this!!!
                          thank you
                              Thanks a lot!!!
                                need 820-2915b schamtic
                                  thanks for the schematic
                                    Trying to open brd file but it returns error saying that is has been copied as ASCII - is it possible to upload it as binary?
                                    Or which board viewer shoudl be used - I've tried with Cadence and it does nto work.
                                    Thank you
                                      I am looking for the 820-2915-A, Macbook pro, late 2011, 15"
                                      ANy advise where i can get it to be able find the components on the board, basically trying to find how to bypass the Fuse for the backight
                                        Thanks for the schematic.
                                          Thank you.
