Re: JVC VCRs
This reply has nothing to do with the fact that I am completely familiar with the units you have been working on. One of them - lucky you - has an automatic azimuth adjusting video drum. HA, one of JVC's dumber ideas. Each time the tape in put in, the drum assembly hunts around for its proper azimuth. The tiny motors wear out long before the rest of the unit. But I digress.
Beginning at the beginning is standard procedure for problem solving. Check your secondary supply voltages and look at them on a scope to be sure they are not full of high frequency switching noise. If they are OK, you won't be wasting your time dreaming about capacitor replacement. Most likely suspects on a partially working supply are 1) 5 volt line incorrect due weak filters. 2) +-30 line (if used) has suffered damage to a diode or filter due to voltage spike. A problem in one of the secondaries will affect all of the secondaries.
Once the supply is working normally, does a tape load and eject? Does it power up and stay on? Does the tuner work? Simple stuff first.
