I have a JBL Northridge E-Series E250P self-powered sub-woofer system. This past weekend, the sub-woofer while playing music started generating some random extremely loud popping noises. This was the first sign of trouble in the 7 years that I have had the system.
While powered down in the auto standby mode, without cause the sub would randomly wake up and generate some mad popping sounds then a while later it would again return to the auto standby mode. This cycle would repeat randomly unless the system was powered OFF using the rear AC power switch.
When I removed the PCB I immediately noticed heavy burned marks on the power section specifically by the +/-15VDC voltage regulators.
Closer inspection showed that the board was populated with caps from CapXon, LASTING, and Su'scon. Since the popping sounds are related to faulty capacitors, I started my troubleshooting by removing each electrolytic cap and tested each one using my LCR meter. My ESR-micro v4.0 has been ordered and is en route
The LCR meter showed that both CapXon GS series caps on the +/- 15vdc rail were open. The LASTING brand cap even though it only filtered a low level signal was found 27% out of tolerance. The remaining Su'scon cap used in a critical power conversion section was also open.
Only the following components listed below were found faulty on the board, but all capacitors regardless of their condition were replaced using EPCOS, Rubycon, United Chemi-Con, and Xicon brands. No reason to deal with this BS again.
C4,9 22uF/25v 20% - CapXon - open
C12 330uF/16V 20% - Su'scon - open
C37 47uF/16v 20% - LASTING - out of tolerance
I re-assembled the unit verified that all popping sounds and random wake-up have now ceased and that the system works as designed.
