DA0X63MB6H1 RevH Quanta X63
    hi
    the problem is:
    there is only 5v present in the board, and the laptop is dead with power button led is on whenever i plug the AC, there is no 3v, even it cannot charge, no volts on the battery terminals
    Re: DA0X63MB6H1 RevH Quanta X63
    Schematic at post 3 https://www.badcaps.net/forum/showthread.php?t=66905
    check PU25 +3V_ALW
      check PU25 +3V_ALW
      on PU5 (as393m) on pin 2 instead of +3v i found only 1.1v
      i also cannot find pu25 which is on the schematic= RT6575ag, i also have ddr3 not ddr4
        i think thats the only schematic available. You need to find the IC that generates LDO 5V and 3V
          on pin 1 of the power button, the volt is 3.3v, and led is always on
            Do you have the same BQ24780S controller as in the schematic on page 52
              yes
                Check the voltage on pins 5,6,27 with the AC and battery atatched.
                https://cdn.badcaps-static.com/pdfs/...2a8abce3d9.pdf
                  all are zero volts
                    Measure the voltage and resistance to GND on +VA_AC and +VA
                      i cannot find +va and +va_ac in bq24780S
