when i turn on, Philliips TV is not on
    Re: when i turn on, Philliips TV is not on
    I test with continuity test The IC901
    Pin 8 is gnd So black probe on it and touch pin3 , it has beep. Also once I plug the board outlet and unplug check pin5 has beep for few min then stop.
      You can't check the ic with a meter.
        Quick question R_J: I see too many arduino scope online. Do you think I can use it here? If yes I can build one.
          Never mind, arduino is 5v one. I can't use it here
            Is it useable to buy?
            https://www.newegg.ca/p/2A7-00BD-00018
              I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183.
                If you had a 5 dollar esr tester you could have taken those caps out and tested them, as it stands you don't even know if they are good or not.
                  what is the power supply board number?
                    dsp-484ap upbpspdel003
                      I have one I will test and update soon
                        Can I buy this power supply?
                        https://www.ebay.ca/itm/TV-Power-Sup...sAAOSwwqVcD9IR
                          C951A = 0.036 (10v 1000uF)
                          C951B = 0.027 (10v 1000uF)
                          C952 = 0.062 (10v 1000uF)
                          C912 = 0.573 (100v 22uF)
                          C906 = 0.042 (35v 220uF)
                          Is it possible to get replacement IC for DNP005 (IC901).
                            Where did you get the ic that is in there now after the original blew up?
                            Maybe that has been the problem all along. There is no datasheet on this ic, so it's hard to know the specs (operating frequency etc.)
                              I bought using ebay and from China.
                              R_J: is there any scope that I can get for 200. I know most of it above 350.
                                Post #92
                                "Is it possible to get replacement IC for DNP005 (IC901)."
                                But you said you already replace it, so what did you replace it with?
                                Post #86:
                                "I found new IC and replaced it. I got 0.210v at C951A and going down. Now 0.183."
                                  Post #92
                                  Post #86:
                                  I bought 3 of DNP005. I blow out and I had extra to replace again
                                    Quick question : ZD907 (UDZSTE-17), it's zener diode. Is it 5.6v or 15v? It's in the standby circuit.
                                      ZD907 is a PDZ13b, 13volt zener
                                        Sorry I want to know ZD904 (UDZSTE-17). Is it 5.6v or 15v? Near C912
                                          What is the number or letter on the diode? You may need to clean the top with alcohol to read it,
                                          There is no datasheet for the ic, but C912 is rated for 100v so this ic's VCC might be higher than other similar pwm ic's.
