TUF505DT : No charge
    Re: TUF505DT : No charge
    Okay, so communication between board and batery is ok.
    Although 25V at ACDRV looks fine, I guess it doesn't harm to check the DC-IN Mosfets in addition for internal short.
    FairRepair on YouTube
      I try to find what happened but to be honest, i follow what mon2 and you telI am what mon2 and you tell me. I'm not too electronically savvy.
      Anyway, the mosfets seem ok, which bothers me even more... Could the IC I changed, the BQ24780S, be out of order?
        "The mosfets seems okay" -->> You mean the DC-IN mosfets or the other three mosfets mentioned by mon2? Any measurements?
        I don't think the charging controller is the culprit here since the board basically works, except you're not concinced about your soldering skills.
          The source & drain resistance values = 0.90k = 900 ohms ? That is very low.
          Reverse the meter leads and confirm this value again.
            Ok, to be more accurate :
            source (1-2-3) & drain (5-6-7-8)
            Left (not on board): black probe on Drain and Red on Source : 1.43K - Reverse : decrease from 13mohm
            Top : black probe on Drain and Red on Source : 6K (sometimes 2K oO) - Reverse : decrease from 300K
            Right : black probe on Drain and Red on Source : 6K (sometimes 2K oO) - Reverse : decrease from 300K
            source (1-2-3) & gate (4)
            Left :black probe on SOURCE and Red on GATE : OL - Reverse : OL
            Top : black probe on SOURCE and Red on GATE : OL - Reverse : OL
            Right : black probe on SOURCE and Red on GATE : OL - Reverse : 82K
            gate (4) & drain (5-6-7-8)[/B]
            Left : black probe on GATE and Red on DRAIN : OL- Reverse : OL
            Top : black probe on GATE and Red on DRAIN : OL - Reverse : OL
            Right : black probe on GATE and Red on DRAIN : 1mohm decrease- Reverse : OL
              I hope someone is still here to give me ideas
              Took a little time as I ordered multiple items. So I changed the 3 mosfets as well as the BQ purchased from Mouser and the result is no better...
              I really do not understand what is happening but I can now rule out 99.99% a problem on these 4 components.
              Having no diagram or boardview, I don't know where to look or what to measure :/
              Thank you very much in advance. Your help is really much appreciated.
                Apply the adapter and the battery.
                Power on.
                Carefully measure the voltage to ground of each pin of the charger IC.
                Post your measurements with the pin numbers.
                  Thank you for your reply.
                  Here are the measurements :
                  1 - ACN : 19.41V
                  2 - ACP : 20.23V
                  3 - CMSRC : 20,02V
                  4 - ACDRV : 25.33V
                  5 - ACOK : 3.123V
                  6 - ACDET : 2.741V
                  7 - IADP : 3,204V
                  8 - IDCHG : 0.015V
                  9 - PMON : 0.336V
                  10 : PROCHOT :0.00V
                  11 - SDA : 3.280V ~
                  12 - SCL : 3.280V ~
                  13 : CMPIN : 2.00V
                  14 : CMPOUT : 4.921V
                  15 : BATPRES : 0.00V
                  16 : TB_STAT : 0.273V
                  17 : BATSRC : 11.13V
                  18 : BATDRV : 10.61V
                  19 : SRN : 10.61V
                  20 : SRP : 10.61V
                  21 : ILIM : 3.138V
                  22 : GND :0.00V
                  23 : L0DRV : 0.00V
                  24 : REGN : 5.998V
                  25 : BTST : 10.34V
                  26 : HIDRV : 10.62V
                  27 : PHASE : 10.62V
                  28 : VCC : 19.90V
                    To me, pin # 10 stick out.
                    This is an active LOW signal. If LOW, there is something wrong.
                    See attached from one of the datasheets by TI.
                    Remove all power. Meter in resistance mode. Measure the resistance to ground of pin #10.
                    Next, meter in DIODE mode.
                    Red meter probe, yes RED to ground.
                    Black meter probe to pin #10 of the charger IC.
                    Post each measurement.
                      In resistance mode, i find 112,6kohm
                      In Diode mode : red probe on ground : 0.554 and black probe on ground: OL
                        In my opinion ILIM stands out too. Would more expect something around 1V than even 3V. You could check PR8913 and PR8914 for beeing inside the specs
                          Thank you but what is PR8913 / PR8914 please ? I don't have any diagram or boardview :/
                            1 - ACN : 19.41V
                            2 - ACP : 20.23V
                            Voltage drop too high
                            7 - IADP : 3,204V
                            Saturated as a result
                              Ok and what do you think about ? Have you an idea ? Thanks very much
                                I still stuck with this charging issue :/ Is someone have a boardview for this laptop please?
                                I don't understand what happen with this case. Thank you very much.
                                  Check the resistance to ground of ACN pin.
                                  Post the measurement.
                                    I find 85kohm between ground and ACN
                                      So no short on the main power rail.
                                      Measure the resistance between ACN & ACP pins. What is the resistance of the current sense resistor?
                                      There should not be such a large voltage drop from ACP to ACN pins.
                                      Perhaps you can measure the voltage to ground again of each of these pins and post your updates.
                                        Ok, so resistance between ACN and ACP is : 168.5kohm
                                        Here are the latest measurements from ground to each pin :
                                        1 - ACN : 19.41V
                                        2 - ACP : 20.23V
                                        3 - CMSRC : 20,02V
                                        4 - ACDRV : 25.38V
                                        5 - ACOK : 3.123V
                                        6 - ACDET : 2.741V
                                        7 - IADP : 3,204V
                                        8 - IDCHG : 0.100V
                                        9 - PMON : 0.030V
                                        10 : PROCHOT :0.00V
                                        11 - SDA : 3.280V ~
                                        12 - SCL : 3.280V ~
                                        13 : CMPIN : 2.00V
                                        14 : CMPOUT : 4.924V
                                        16 : TB_STAT : 0.100V
                                        17 : BATSRC : 11.12V
                                        18 : BATDRV : 11.12V
                                        19 : SRN : 11.12V
                                        20 : SRP : 11.12V
                                        21 : ILIM : 3.141V
                                        22 : GND :0.00V
                                        23 : L0DRV : 0.00V
                                        24 : REGN : 5.999V
                                        25 : BTST : 10.84V
                                        26 : HIDRV : 11.12V
                                        27 : PHASE : 11.12V
                                        28 : VCC : 19.90V
                                          OMG...can you check the acn to acp resistance again?
                                          Waaaay too high. Check the schematics (not at my desk now) but it should be ~1ohm or less.
                                          This is a serious fault if the reading is accurate.
