Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Appliances and other Household Electronic Stuff
Thread Tools Display Modes
Old 01-19-2023, 01:32 AM   #1
Use2bavolvo
City & State: Burnaby,bc
My Country: Canada
I'm a: Knowledge Seeker
Default Magic chef oven - thermistor ref voltage issue
I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting is much higher..
Anyone have any thoughts on what's going on? I plan on rreplacing the caps this thing is 30yo.
I've also I'd a fan resistor that's not registering any ohms ATM the fan runs all the time so not sure if that's also causing the issue.
Use2bavolvo is offline   Reply With Quote
Old 01-19-2023, 05:19 PM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Default Re: Magic chef oven - thermistor ref voltage issue
Are there any components on the other side of this board if so could you post the picture of the back of the board
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 01-19-2023, 06:23 PM   #3
redwire
City & State: Alberta
My Country: Canada
What's the oven's model number? If the controller thinks the oven is hot, I'd expect the fan to be running. Have to take ohmmeter readings of the sensor or the control board has an issue.
redwire is offline   Reply With Quote
Old 01-19-2023, 06:36 PM   #4
Use2bavolvo
My Country: Canada
Model C9875VRV
Control Board part number 7601P225-60
The top board has 3 separate single layer boards this top board does not have any other components just traces.
Middle Section is where the IC is
Bottom Section is for the controls and display
The thermistor is reading correctly at room temp and when hot.
The R4 resistor is a bit of an oddity I read it as Violet, Yellow, Yellow, Red, Red which is a odd ohm 744k (there is no resistance across this) Can I just replace with a 750k 1% resistor here?
Old 01-19-2023, 06:51 PM   #5
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
R4 value looks like 2.2Ω 5ppm/K, have you checked it's resistance?
R_J is offline   Reply With Quote
Old 01-19-2023, 07:10 PM   #6
redwire
My Country: Canada
Oven temperature sensor WPW10181986 commonly used in Whirlpool, Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, Admiral, Norge, Roper, Sears/Kenmore and others.
It's an RTD (not a thermistor) aka Pt1000 so resistance goes UP with temperature. Resistance table is like this pic.
Check the sensor resistance with a multimeter, as well check isolation resistance to the sheath/chassis to see if it has a ground fault. Check the connector is not corroded/melted as well because only a few ohms change causes large swings.
You can also jumper in a resistor in place of the sensor, to see what the control board displays.
1,000Ω should read around 32°F/0°C if the oven is OK with such a low temp.
2,200Ω should read around 613°F/323°C.
Old 01-19-2023, 11:39 PM   #7
Use2bavolvo
My Country: Canada
The resistor is between the relay and fan pin. I did some more research it looks like a fuse resistor does that seem right?
Old 01-20-2023, 12:09 PM   #8
R_J
City & State: ☻
My Country: Canada
Yes it could be a fuse resistor, What resistance value does it measure?
Also post a clear picture of the back of that board so we can see what it connects to.
Old 01-20-2023, 10:44 PM   #9
Use2bavolvo
My Country: Canada
R4 is open no resistance
Back of board traces
Second board pic
Also transformer between
pin 1-4 142ohm
pin 8-5 175k ohm
Diode 4 and 5 both registered .526 but when tested other way around went up to 2.0 then 0 not sure if that's from the transformer??
Old 01-21-2023, 12:45 AM   #10
Use2bavolvo
My Country: Canada
After reading about capacitors when degrade creates resistance on the circuit I'm gonna replace the power caps to ensure this is generating a stable voltage. 30y its due.
Old 01-21-2023, 11:52 AM   #11
redwire
My Country: Canada
R4 fusible resistor is for the DLB safety relay K3, I'd say it blows if there ever is a DLB problem. Who notices? Must be a repair indicator.
Has the oven ever had a failed heating element (ground fault)? That can take out the temp sensor and circuitry.
K3 has a fractured soldering joint on the spade BTW. Other touch ups look like not enough heat/time for soldering technique on the big through hole parts. Jack up the iron temp at least 700°F/370°C and hold for a second or two longer.
Given the age 30 years and rarity of this board, I'd replace the electrolytic capacitors certainly on the PSU/Relay board, and only 3 on the MCU board.
The temperature sensor circuit is another thing to troubleshoot.
Old 01-21-2023, 11:11 PM   #12
Use2bavolvo
My Country: Canada
Looks like we may have found the issue..these caps in macro look buldged out. Digikey didn't have this form factor they are height of 6mm 4.7uf 35v
Old 01-22-2023, 04:28 AM   #13
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Such small caps don't bulge, what you are seeing is just the heatshrink sleeving.
That said they do dry out and after 30 years they are probably bad if they ran at all hot, so good idea to swap them out.
__________________
Per Hansson is offline   Reply With Quote
Old 01-22-2023, 04:27 PM   #14
Use2bavolvo
My Country: Canada
Parts ordered was able to get the 4 relays as well. Wil update after I get em soldered in. I wasn't able to get current trim on the caps so just went with uf and v plus length which were requirements for the in between board caps.
Old 01-23-2023, 07:10 PM   #15
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
With the longer replacement caps, you can just lean them sideways on the board. That should allow you to fit standard 5x11 mm caps. As a bonus, since they are bigger, they should probably last longer too.
Old 01-24-2023, 11:57 PM   #16
Use2bavolvo
My Country: Canada
Update of everyone.
I replaced 6 caps
3 on power board and 3 on logic board
Happy to report oven is fixed
Recap - thermostat was correctly measuring 1060 ohms at room temp
Oven temp would register 300f at room temp
Relays would come on when temp set to 515 and will get to 350 but wouldn't stay there.
Measured VDC at thermostat connection to the board ~3.8 or lower vdc. With thermostat disconnected 9.8v
The thinking was the ref voltage was low so temp was being read wrong by ic
One of the PSU caps was toast dumno if the others were bad but replacing them fixed the issue.
Oven temp at room is now normal and relays bake and broil are all turning on when they should.
Thx folks learned a lot about bad caps and sad to see the manufacturer killing off smaller spec replacements.
Invaluable learning experience and super helpful group!!!
Old 01-25-2023, 12:38 AM   #17
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Nice work, great to hear you got it working!
Also, thanks for coming to report back. I think this will definitely help others who may experience this issue, since now we know the caps did fix it.
Old 01-25-2023, 12:18 PM   #18
redwire
My Country: Canada
Can you post the cap size and values you replaced, to help others doing this repair.
It's great you got it fixed, the oven control boards are either super expensive (trending at $450) or discontinued. All this e-waste when people are broke.
I thought it was the caps or the op-amp chip LM324 is the only thing left.
Old 01-25-2023, 09:39 PM   #19
Use2bavolvo
My Country: Canada
Power board 2x 1000uf 35v
Power board 1 47uf 25v
Ic board 1 47uf 25v
Ic board 2 4.7uf 35v
Attached component bought from mouser. I bought the 4 relays but didn't install them. These become unobtainium so figured best get spares.
I agree with your comment about the disposable appliance. These things are dead simple devices which should be repairable but most die within 5 years.
My appliances are all analog so they have survived a long time dryer is circa 1993. Only thing I've gotten for that is a blower fan blades plastic and a overheat switch which died and some drum rollers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
