3. Flash Program Options *
* To deploy this application, please open the Windows Command Prompt *
* with Administrator privilege. Then run "xxxJYnnUSA.EXE -s -e" *
* to unpack the installation files into the default path: *
* "C:\SWTOOLS\FLASH\xxxJYnnUSA". After that, run "flash.cmd /quiet" *
* to start the update process. If you like to customize the update *
* options, please edit the wflash2.exe command line in the flash.cmd *
* file to make changes to the flash program options. *
* Note that "flash64.cmd" and wflash2x64.exe are provided to be used *
* in an environment without WOW64 support such as Windows *
* Preinstallation Environment (Windows PE) 64bit. *
* Command options: *
* wflash2.exe [option1] [option2] ... [optionX] *
* [OPTIONS] *
* /h Show help messages. *
* /rsmb Preserve all SMBIOS structures. *
* /clr Clear BIOS settings. *
* /ign Ignore BIOS version check. *
* /sccm Support SCCM deployment *
* - see "Delaying Reboot in BIOS Update" below. *
* /sn:nnnnnnn Update system serial number (up to 20 characters). *
* /csn:nnnnnnn Update chassis serial number (up to 20 characters). *
* /mtm:nnnnnnn Update machine type and model number (up to 25 *
* characters). *
* /tag:nnnnnnn Update system asset tag (up to 25 characters). *
* /uuid The flash utility will generate an Universally *
* Unique Identifier (UUID), replacing the one that *
* is currently in the system.
You`ll have to use wflash2.exe to update the bios and add the DMI. Heres the instructions from the bios update readme
Hello friend, i have a Lenovo V130-20IGM, I recovered the bios with the dump from this post (Thanks), but I have an error and I don't know how to fix it, colud you help me please? "Error 0167: No Processor microcode update found"
Reason: Edited full quote
