Proline 42" Model JV427A Plasma (PDP42V7)
    Hi guys,
    I got in this set with a faulty Y-Sus board but i have brand new boards for this set so i swapped out the Y-Sus and tv started up perfect except for this.....
    On various inputs the TV it is in "burn in" mode, cycling through a red, green, blue image and displays burn in at the bottom. If however i give it a input like my DVD on AV1 then the burn in image goes away and the DVD picture shows up perfect. If however i switch to "TV" input (RF, VHF & UHF) then i get a perfect picture straight away.
    It is as if it has been set up in service mode to go to burn in when there is no input. Is there a way to disable this burn in test, service mode entry?? I don't know how to enter service mode on this dinosaur.
    PS: Photos attached
    Thanking you in advance.
    Re: Proline 42" Model JV427A Plasma (PDP42V7)
    The main board looks like a philips board so maybe try with philips service codes.
      So you agree it could be a service setting?
      Will check philips codes
        Hi R_J,
        I finally got the remote. Check photo.
        Unfortunately i dont know philips service mode entry codes. Could you elaborate so that i can try.
          here are a bunch of philips codes, I doubt they will work.
          PHILIPS-1
          # Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
          or
          # Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
          or
          # Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
          # Turn the TV off to exit the Service Menu.
          PHILIPS-2
          * Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
          or
          * Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
          or
          * Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
          * Turn the TV off to exit the Service Menu.
          PHILIPS-3
          * Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
          or
          * Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
          * Turn the TV Off to exit the Service Menu.
          PHILIPS-4
          * Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
          or
          * Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
          PHILIPS-5
          * With the TV off:
          here is the Haier service menu:
          Press V- , turn volume to 0
          Press "menu" on tv
          Press "menu" on remote control
          Press and hold V- for 3 seconds
            Sorry for the late reply but i never came right on this one.
