On Friday evening, as we were preparing to close shop, my boss says to me that one of his faithful customers is going to come in with a video card that's been misbehaving and he wants me to look at it.
I expected something along the lines of a 8800gtx, but instead, what he brings in is this... I immediately said that even LOOKING at that is going to cost $$. I started taking it apart as soon as he brought it in, exposing a huge motha' BGA with an IHS on it. Well, that's a big one... I'm well used to reballing and replacing laptop BGAs, but this is ONE BIG CHIP. I took only the card itself home and left the cooler and all the screws at work (i no longer have a desktop PC so i don't have a way to test it at home) and said i'll give it a shot. Told the guy we'll ring him to bring his PC in so we can test the card once it's done.
I have recently bought a big pack of BGA reballing stencils and when i saw the size of the ones meant for desktop nVidia cards i thought no way in hell am i ever going to use those. Well, i guess the time has come for me to use them.
I had my doubts i was even going to be able to lift that big motha' on my makeshift BGA station, but with the 45x45mm nozzle and a bit of patience, it came off clean. Cleaning it was a different story - due to the huge thermal mass of both the PCB and the chip, i had to use the hot air wand and soldering iron + braid at the same time to get all the solder to come off the pads. But with a bit of patience it all got cleaned up with no mishaps.
Also when reballing i had to make use of the preheater, placing the chip on a piece of floor tile and heating that up before i started heating the balls with the hot air wand, as due to the IHS there was no way i could've gotten the balls to solder to the pads with the hot air alone.
The IHS also came off at two of the corners due to the heat, which made it easier to remove. Once i got the IHS off it was obvious that it HAD to be removed - the paste between the die and the IHS was completely dried out. I have also measured the SMD capacitors around the die and there are no shorts, so it should be good. As you can see, i did scratch the substrate a bit when removing the IHS but it's only superficial and should not affect the functioning of the chip... we'll see.
Resoldering the chip to the PCB was much easier with the IHS removed. All checked out okay, we'll see on Monday if it actually works. Wish me luck.
