As I mentioned in my previous thread, my TV has recently bitten the dust and won't power on (it only makes a loud buzzing noise). I have a spare TV which I'm using right now, but it has a couple of things wrong.
First, and most annoying, is that it makes a loud high-pitched noise when on. I don't mean the quiet whistle that most CRT TVs make when switched on, this sounds similar but is MUCH louder. Sometimes, if I hit the top of the TV, the noise will stop - only to come back a few minutes later.
The second thing is, the colors are much too bright - I have to turn the color control down to make them look right. If I touch the buttons on the front of the TV, the color level changes and occasionally goes back to the 'proper' level. I assume there might be a loose wire or dry solder joint on the board - what do you think?
It's a Sony Trinitron set, 14-inch screen, PAL (60hz compatible) with mono sound. A friend of mine (who is good with electronics) says that I should try reseating the suction cup on the tube to try and fix the whistling problem. But to do that, I'd probably need to discharge the tube. I read somewhere about wiring a screwdriver to ground and pushing it under the suction cup, but that sounds dangerous! How DO you go about discharging the tube and reseating the suction cup anyway?
