Hi have laptop asus x502ca with motherboard hannstar j mv-4 94v-0 e89382 but no wifi ,try to change another wifi card but same so probably card not getting power because of bad weld or failure components .Any suggestion please or should I put her in oven for baking thx
asus x502ca motherboard wont recognise wifi
Re: asus x502ca motherboard wont recognise wifi
I've seen similar issues a few times, and almost always it has been right before a chipset/graphics controller failure, due to bad solder balls condition. If you are planning on a homemade repair I wouldn't recommend an oven "fix"/reflow. It is much better to use a heat gun and flux (no-clean flux).
But you should not start reflowing things on your board, before you are 100% that a bad chip connection with the motherboard is the problem.Keyboard not detected, press F1 to continue...
