Dell XM091 (PowerEdge 840) - Help identify caps
    I was wondering if you guys could help me identify these bad caps and tell me what I should replace them with.. :/ I've attached two pictures of each side of the cap to help provide as much info as possible.
    Re: Dell XM091 (PowerEdge 840) - Help identify caps
    That is a United Chemi-con KZJ 1800uF 6.3V cap.
    Depending on the dimensions of the above cap, Badcaps.net sells 2 Rubycon MCZ versions of the 1800uF 6.3V cap just in different sizes. Choose the size that matches your United Chemi-con.
    See
    https://www.badcaps.net/pages.php?vid=22
    --- begin sig file ---
    --- end sig file ---
      Have you encountered bad caps in this unit or not?
      I have a couple of these in service...
        I have more then a couple of these servers and have never had a problem with bad capacitors in them.
          Glad to hear, I didn't want to spend the next however long they're still in service for, fretting about them.
            Excellent! I just ordered these:
            https://www.badcaps.net/store/produc...products_id=37
            The motherboard has 3 of these... one of them was bulging out and oozying out of the top.. the other two looked ok but I figured I'd replace them since they are the same kind of caps.
              Thanks everyone!!! I really appreciate it.
                OK, had one of the servers I was talking about on the bench - PowerEdge 800, not 840.
                Everything happy inside, almost all Rubycon with a few Chemicon.
                  it's an old thread but at year 7; i've noticed that my poweredge 840 has a bad cap. in fact, on ebay; i notice that the cap failure is always at the same point around the cpu.
                  i will be swapping in my backup server's motherboard and then recapping them; will post pictures then.
