HP Elitepad 900 BIOS
    Is it possible to remove password from my HP Elitepad 900 BIOS dump please?
    Chip Winbond 25X40CLSIG.
    Thank you!
    Best regards!
    Re: HP Elitepad 900 BIOS
    try this one and report result.
      Thank you!
      Best regards!
      It isn`t the full bios only part of it. The other part is probably in the eMMC, you need an eMMC reader/programmer.
        It's working thank you!
          its strange, theres not much difference between the two files .
            SMDFlea, Hp unlocker was used, I did not mess with the ME region, I am surprised and happy it worked too.
              Password is stilo on.
                Working bios in english with no bios password
                  hello friend i would like some help to locate the IC to read the BIOS please...
                    post clear pictures with the motherboard and someone will help you.
                      Hello.
                      My HP ElitePad G1 not install any OS after bio setting update.
                      I need your help
                        Originally posted by Schakall View Post
                        Hello.
                        I need your help
                          HP ElitePad 900 G1
                          Hi !
                          I try to remove the BIOS password on a HP ElitePad 900 G1 but the file patched by HPUnlocker don't delete it.
                          I also try to use RcUnlocker to patch my binary but the .exe constantly return me "mssing unlockable content" (i drag/drop the .bin file to .exe)
                          Serial number: CND34311TN
                            Re: HP ElitePad 900 G1
                            Originally posted by Tomcat01 View Post
                            Hi !
                            try this.
                            all donations are welcome,
                              Originally posted by volinakis View Post
                              try this.
                              work perfectly ! thank you !
                              I'm begginer with chip flashing and i'm curious to know how the procedure work
                              i checked my .bin source with yours with HexCmp and i notice a lot of changing in the data, what i did wrong ?
                                I took bios from post #8 which is reported as working with no password and put your DMI into it. only works this way in few old laptops, is not a general rule. if you want to learn more about bioses you should read BIOS guides, methods, resources and tools section.
                                https://www.badcaps.net/forum/showth...t=phoenix+bios
