Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Audio Equipment Discussion
Old 09-14-2017, 07:01 AM   #61
srt1
City & State: calicut
My Country: india
Default Re: Pioneer VSX-520-K Protection problem
Originally Posted by rievax_60 View Post
The solder ball shorting Q437 would explain all of the damage you have found so far plus more possibly. Check all resistors in the area including R573.
I would not expect any damage to the output transistors or Q445.
Faults that cause amplifier outputs to go DC don't necessarily cause any extra damage.
Already i checked all the components the damages are found as below
1.ZD410(shorted)
2.Q443 Q444, Q417(blown)
3.R551 and R493(burn mark)
4.C531 (blown)
Rest of all components i ddint find any damages also i checked with multi meter
I will do test run evening then i let you know
srt1 is offline   Reply With Quote
Old 09-14-2017, 01:32 PM   #62
srt1
My Country: india
Hi.. i replaced Q417 with A684 transitor now i am geting -B volt around -50volt and i checked all chanell ther is no dc volt presents..but when i checked SL still ther have dc volt present.here i used a684 transisotor as replacemnt for q443 and q444 ..should i use same part number transistor here?
Old 09-14-2017, 02:13 PM   #63
rievax_60
City & State: mackay
My Country: australia
Line Voltage: 240
I'm a: Hobbyist Tech
The correct transistors should be used to replace Q443 and Q444. What is the output voltage and polarity?
rievax_60 is offline   Reply With Quote
Old 09-14-2017, 07:08 PM   #64
srt1
My Country: india
Output voltage is 53 volt plarity positive .. also i checked voltage at emitter tied of Q443 and Q444 its show -13volt(negative), but in all other channels its 0.65volt (,positive)
Old 09-14-2017, 09:04 PM   #65
rievax_60
Line Voltage: 240
Also check the Base voltages of Q443 and Q444. ZD410 should have about 5v across it. The combined voltage across R531 and R706 should be about 4.4v.
Have you replaced ZD410 with a 5.1v zenner diode? Are R531 and R706 ok?
Old 09-14-2017, 09:15 PM   #66
rievax_60
Line Voltage: 240
Q444 might have a problem.
Old 09-15-2017, 12:56 AM   #67
srt1
My Country: india
R531 and r706 are ok .voltage accrose zd410 is 4.47 volt that is same on other channel also base voltage of q443 and q444 are same its -3.1volt but in other channel its 0volt
Old 09-15-2017, 01:02 AM   #68
srt1
My Country: india
I used a684 instead of a992 as per data sheet a684 VCBO IS -60VOLT and Vceo is -50volt but for a992 is both are -120 volt ..tjis diffremce will cause transisotr not work?
Old 09-15-2017, 02:32 AM   #69
rievax_60
Line Voltage: 240
What is the combined voltage across R531 and R706 ?
Old 09-15-2017, 02:39 AM   #70
srt1
My Country: india
That is 3.9volt. in other channel also that is same
Old 09-15-2017, 02:55 AM   #71
rievax_60
Line Voltage: 240
Im having trouble thinking of a definite reason. Somehow, current seems to be flowing from a negative rail to the emitters of Q443 and Q444 via some abnormal path. There might be a solder bridge somewhere or Q444 might be faulty.
Old 09-15-2017, 02:59 AM   #72
rievax_60
Line Voltage: 240
I hope that you are not using acid flux? Are the 2sA684 new parts or pulls?
Old 09-15-2017, 03:03 AM   #73
srt1
My Country: india
Ok that i am.checking now ..
Old 09-15-2017, 03:07 AM   #74
srt1
My Country: india
That i am checking now
Old 09-15-2017, 03:15 AM   #75
srt1
My Country: india
I am using fulx its like paste not liquid.2sa684 is new ..i hav 3 more with me i will try to replace..but when i am checking with multimeter it is ok... Any way i wil check the traces for any shortage
Old 09-15-2017, 03:23 AM   #76
rievax_60
Line Voltage: 240
Also clean the solder joints after soldering. I use a toothbrush and turpentine. Alcohol is good.
Old 09-15-2017, 04:01 AM   #77
srt1
My Country: india
I replaced q444 and cleaned now i am getinf diffrnt reading. Base of q443 is 0volt base of q444 is 6.3volt and emiter tied jucntion geting -4.6volt
Old 09-15-2017, 04:11 AM   #78
rievax_60
Line Voltage: 240
It still looks like high PCB leakage. The 6.3v on the base of Q444 doesnt make much sense unless D449 and D550 are missing?
Old 09-15-2017, 04:14 AM   #79
srt1
My Country: india
D449 and d550 is not present on board but its shows in scematic
Old 09-15-2017, 04:21 AM   #80
rievax_60
Line Voltage: 240
Ok, that helps to make sense of the voltages. The leakage has to be between collector and base pads of Q444. Try to clean it again. Do you have any information about the flux?
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
