#21 |
City & State: Milwaukee, WI
#22 | |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
![]() Quote:
The question is, what is the TV/ Boards not doing? What kind of testing have you done and did you read the whole thread?
Never stop learning Basic LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#23 |
![]() That's what I thought. I just wanted to make sure before tearing it open. Nudged it a tad and TV turned right back on. Thanks!
#24 |
![]() One more saved from the landfill sounds good to me.
#25 |
City & State: stoon
My Country: Canada
![]() Just reporting another 45VE5 saved by this thread. It had sat around for a good year or more and I just cracked it open and found no standby power and everything dead on the power board.
Found this thread and went straight after that RY6000 relay and found that holding it down while plugged in turned on standby power which then made the power switch work and the TV fired right up. Cleaning the relay didn't help anything and I couldn't find my soldering iron so I just used electrical tape to hold the relay down for good. I tested it with the kill-a-watt and found the draw on standby with the relay held down is ~0.5 watts. If this doesn't hold I'll do the bypass fix posted above but I believe taping it accomplishes the same thing. Anyhow, thanks for the good work above guys! |
#26 |
City & State: midwest
My Country: U.S.
![]() So the problem is a bad relay then, correct?
#27 |
City & State: stoon
My Country: Canada
![]() Not necessarily, I think it could also be a resistor or something that energizes the relay. I’m not the best with electronics troubleshooting at this level so I didn’t go much farther than what’s in this thread.
Seems like a common issue though, never would have got it without this thread. |
#28 |
![]() If R6016 is open then there will no Voltage to feed the bridge rectifier D6000 so there will be no standby Voltage, the relay is used for bypassing the resistor when TV is turned on because you do want to have 6.8 Ohms resistor in series with the load, in standby the resistor does not dissipate much heat but when TV is on then resistor will dissipate lots of heat that is why it is bypassed by the relay.
If you want to bypass the relay contact you can just bridge the two solder pads of the relay contacts, no need to cut any trace and reroute the Hot and Neutral traces which is not a good idea. |
#29 |
My Country: U.S.
![]() Thanks Bud.
#30 |
![]() "because you do want to have 6.8 Ohms resistor in series with the load"
Correction, it should be 'you do not want'. |
#31 |
City & State: stoon
My Country: Canada
![]() Great, thanks! My electrical tape fix didn't hold up, so ended up just bridging the relay pads as you suggested. Back up and running for good.
Just out of curiosity, I was wondering what the point of this circuit is in the first place, if bypassing it causes no problems? Last edited by adster; 10-27-2019 at 05:00 PM.. |
#32 |
![]() please help me to find volts PRI_VCC on C6206 sony G6 power supply
#33 |
City & State: ☻
My Country: Canada
![]() Why ask on every thread, start your own thread
#34 |
Old Member
City & State: Quebec
My Country: Canada
![]() Just to let you know that your modification saved another Sony KDL-46VE5
I cut the trace and added the 2 jumpers on the power board and now it REVIVE ! A big thanks to you. I found this TV on my street, saved from the trash. Have a nice day Quote:
#35 |
City & State: ☻
My Country: Canada
![]() This is not the way to repair this problem, Just replace the open R6016 resistor and relay.
#36 |
![]() End results, though.
After six more years of service, the original device was retired. While the screen was still good everything else was failing - audio output full of static, all digital inputs dead, needed an HDMI-to-composite converter to use it at all, video signal would drop out after being used for a few hours. I suspect the power supply but no time to dissect it. |
Thread Tools | |
Display Modes | |
