Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 01-23-2014, 04:23 PM   #1
koresi
City & State: Timisoara
My Country: Romania
Default asus k50ij dead
hello,
i have an asus k50ij with no led lights and no charging;there is only +19V and 3,3v for EC also EC_reset but no VSUS_ON.
I have checked the EC inputs everything seems to be ok...AC_IN_OC# is 3,3v...EC clock is 32 Khz..
I would change the EC but i want to be sure that EC is defective...
Any hint?
Could be the bios chip?I am not sure that the EC needs bios to rise up the VSUS_ON signal.
Waiting for your opinions...
Best regards.
koresi is offline   Reply With Quote
Old 01-24-2014, 03:25 AM   #2
sopik78
sopik78's Avatar
City & State: Boskovice
My Country: Czech Republic
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: asus k50ij dead
Try charger IC MB39A132 and related FETs
sopik78 is offline   Reply With Quote
Old 01-24-2014, 05:34 AM   #3
Francisco.s
City & State: Madrid
My Country: Spain
Could you measure a high level at pin 19 (VSUS_ON) of IT8502?. (U3001)
If so, did this voltage gets to J8111 to reach VSUS_ON_PWR point?
(VSUS_ON--> VSUS_ON_PWR--> ENBL)
This mobo has JP8113 pads, to POWER TEST the pwm circuit of 3,3 and 5 volts.
Check and post results.
Francisco.s is offline   Reply With Quote
Old 01-24-2014, 05:49 AM   #4
whaldsz
City & State: NE
My Country: Philippines
Line Voltage: 220VAC 60Hz
Originally Posted by koresi View Post
hello,
Any hint?
Best regards.
Check if you get 3.3v at RSMRST#.
whaldsz is offline   Reply With Quote
Old 01-24-2014, 03:34 PM   #5
koresi
My Country: Romania
no,there is no voltage on pin 19 of IT8502.
Old 01-24-2014, 03:39 PM   #6
koresi
My Country: Romania
i did not checked the RSMRST# signal,but i think it becomes active after VSUS_ON and SUSPWRGOOD.
I will check and tell you.
thanks.
Old 11-30-2017, 02:35 PM   #7
desktop85
City & State: Aragua
My Country: Venezuela
I've the same board with the same problem, I solder the test pad JP81113 to power on the PWM U8101 ( RT8206AGQW ) but nothing happens, I've checked the power mosfets that the U8101 controls but are ok. Also I replace the PWM by other compatible ISL6236 but nothing.
I solder the test pad because I don't have the ENBL signal.
desktop85 is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
