dell optiplex 3090 bios issue please help!!
    Re: dell optiplex 3090 bios issue please help!!
    Originally posted by hardware1 View Post
    One of these files should fix your Problem.
    Thank you sir
      Need bios unlock file
      Serial no. : CB26KN3
      Along with the steps please.
        DELL OPTİPLEX 3090 CHDP9N3 there is a bios password does anyone have a solid file
          Help dell optiplex 3090 need absolute computrace to disable, but it is locked in the bios,
          Service Tag: CR294K3
          Thanks in advance.
            Need help dell 3090 mini absolute lock hope someone can help tnx...
            Service tag: 60SPVP3
              Up
                Good day can anyone remove Absolute in my dell 3090
                Service Tag: 7MJW6L3
                THANKS in advance.. Your help is truly appreciated.
                  Upload backup bios, i will help you, i found a way by myself
                    Thank you sir @Arrow16..Here is my back up file thanks alot.
                      Giv feedback... Enjoy
                        Thank you very much sir..I will test it later..Cheers, God Bless...
                          Good eve sir Arrow16, thanks for the firmware I test it but still have absolute enable ..
                            Here try give feedbacl
                              Thank you sir it works I permanently disable the Absolute..Thanks you very much sir,..pm kita sir,thanks
                                Good Eve Sir,
                                How could i create a back up file (bin) bios for optiplex 3090 micro.
                                  help bios password issue, Dell OptiPlex 3090 Small Form Factor.
                                  Servis TAG: F9DP9N3
                                    Hope you are doing well. I have an admin password locked Optiplex 3090 Micro and was able to extract the locked bios with a CH341a and a SOP16 clip.
                                    Would be really nice if one could unlock my Bios file.
                                    Kind regards, Elmotastic
                                      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                                      all donations are welcome,
                                        Servis TAG: F9DP9N3
                                          Originally posted by jhaydee14 View Post
                                          Good Eve Sir,
                                          Just a short summary what worked for for my dump. I purchased a SOP16 test clip and soldered the eight wires to it. Actually I purchased another one pre-wired that did not create a stable dump.
                                          With an CH341a Pro set to 3.3V I was able to create a dump with flashrom on Linux and write the patched one. I had to remove all components from the board.
                                          The wiring was simply taken from the chips datasheet:
                                          https://cdn.badcaps-static.com/pdfs/...0d14ff4525.pdf
