Thread Tools | Display Modes |
#1 |
City & State: Leyte Palompon
My Country: Philippines
I'm a: Knowledge Seeker
![]() Hi i got a same problem on my k50ij main board rev 2.1 it wont turn on . .i just used yesterday everything is Good.but now it wont
No lights or total dead.i need guide were to look |
#2 |
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
![]() Check if there is a voltage out of the power adapter.
Then mate it to your laptop and confirm the voltages on the logic board starting with the dcin power connector. |
#3 |
![]() I notice the power switch wont turn on or it doesn't work .
is there a way to make it auto on while i plug my charger? |
#4 |
![]() Does Anyone had an idea to auto startup a k50ij asus laptop ?when i plug my charger? Cause power button is not working.
#5 |
My Country: Canada
![]() Is that the only fault with the board?
Will check against the schematics once at the office. |
#6 |
My Country: Canada
![]() See above. Locate and confirm if there is a pushbutton switch on your board to mimic the on/off function.
#7 |
![]() Yup thats it on boardview .im now quite confused 😶😶😶what is negative and positive to make it turn on .also i try buy the button for my laptop but its not available on my hometown.can u gave me a switch type i should used,?
#8 |
My Country: Canada
![]() Measure the voltage to ground of pins 1 & 3 (either is ok as they are the same).
If you use tweezers or a piece of wire between pins 1 & 2 OR 3 & 4 (either pair is ok), this should act like your ON/OFF button. That is, when the ON/OFF signal line is brought to a LOW level, you should be able to turn ON the logic board or OFF if it is ON. |
Thread Tools | |
Display Modes | |
