Aircon regasser,Could bad caps be the problem here?
    I have this aircon regasser in from a friends garage. The values fluctuate on their own when they should be giving out a solid reading. My first thought was capacitors so I have replaced the lot, just looking for a second opinion before taking it back for testing. One of the 10uf capacitors had an ESR of 1.8ohms the new ones I have fitted are a little less. Hoping this will solve the problem, I can't find any shorts or other faults on the board but as I don't have a schematic I'm not 100% sure what readings I should be getting.
    Pictures here: https://imgur.com/a/FVSajwR
    Re: Aircon regasser,Could bad caps be the problem here?
    You did check the battery voltage, correct?
      1.8 ESR reading might be a little bit high depending on the type of circuit that you have
      Because on some switching power supply circuits get flaky when ESR is higher value than than a new one
      Keep in mind that an ESR does not put the capacitor under a load condition and sometimes a capacitor can check on a meter but fails under a load condition
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        Sorry guys, I didn't realise there was any replies here.
        I did swap the battery and all the caps, on the bench the board had solid readings so I was 99% sure I had fixed the problems.
        But when I went to test on the machine, it had the same results.
        The bosch engineer said he had swapped the scales which is an all out lie, he then blamed everything on the circuit board. I have the whole thing here now and am unsure what more to do other then swapping some of the chips.
        The scales seem to be working as when I pull on the bottles the value does increase but when left at their usual state the value fluctuates which is what is confusing me.
        I have some pictures of the scales and a video of the fluctuating values here: https://imgur.com/a/LVcUhxW
