Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by salmad View Post
    Hi someone have dump for Hisense 32h3e Main .Tp.ms3393.pb851
    pleas help i need this dump
    https://***********/threads/devant-3...3-pb851.35301/
          Originally posted by dani502017 View Post
          After if its ok go to Copy Pattern profile for MB95M
          Here the procedure is a bit more complex, so will be created two folders
          1.downloadprofile.mb95 - responsible tuner, audio, subtitle
          2.downloadpq.mb95 - panel responsible (display)
          The operation is the same as the FAT32 stick, make the two folders with the above names, insert the stick into the TV, go into service with the MENU 4725 and the "USB OPERATION" option is ok from the remote control.
          After upload here the file,will then help repair
          Hello again,
          I finally got the TV to switch on but screen is scrambled & upside down,
          I have downloaded the files you requested as follows,
          Thank you
            I'm looking for two Eeprom dump for Q.Bell TV .
            MARQUE : Q.Bell led tv
            MAINBOARD: T.MSD309.B63B
            MEMORY: 25Q32
            PANEL: M185BGE - L23
            and
            MEMORY: 25Q32
            PANEL: LM215WF4 (TL)(G1)
              MEMORY: 25Q32
              and
              MEMORY: 25Q32
              i have 3 files of this board but panel no. are different 1 is unknown and 2 are 1920x1080 res.
              if you need i will upload
                Croma_CREL73151
                panel K320WD3
                board 4715-MV59T9-A2233K11
                  plaise help
                    hi all,
                    we have lg=32lh604v .we want 1367*768 resolation file .
                    any one help me?
                      hi ; i need dump lg 50pn450b
                      eax65071308 (1.2)
                      pdp50t50010
                      lge pdp 130613 .
                      thanks...
                        plaise help
                        this model 32d37 have similar mainboard (pb851)
                          Thank you my friend 10/10
                            Hello, does anyone have a dump for Samsung C6000 series?
                            TV Model: UE40C6000RWXXH
                            Mainboard: BN41-01444B / BN94-03611S
                            Chips are:
                            IC7301 4256BRP
                            IC4002 S24CS0
                            Thanks..
                              Hi All
                              Does anyone have the dump for a COBY TFTV4028
                              Main Board---002-FV40-2812-00R
                              Panel---T400HW03 V.2
                                Hello
                                I would really appreciate if someone could share dumps for a SONY KDL-32BX400
                                Main Board :A-1738-304C.
                                Thanks in advance
                                  SALUT tt mes freres je cherche dump de tv LG 19 LP68A
                                    Is there a way to prevent the Eeprom from going bad? I am guessing they do not over heat so what is the cause other than static or a power surge?
                                      Hello
                                      I really appreciate if any member could share a dump for a TV LED Blaupunkt 39/401l, or some other brand that uses the same mainboard/panel combo
                                      Modelo Nr: 39/401L-GB-5B-1HUHBKUP-EU
                                      Modelo Ref: B39A401TCUHD
                                      Mainboard: TP.MSD309.BTU87
                                      Panel: v390DK1-LS1
                                      Thanks in advance
                                        Originally posted by Hamie View Post
                                        17mb82s
                                        PANEL: VES490UNDL-2D-NO1
                                        both U10 and U12 flash.
                                        tested and working.
                                        U10 - 25Q16DV
                                        U12 - 25Q64FV
                                        Hi All
                                        I have hardware like above i reflashed u10 and u12. tv turned on but my screen is upside down and blurred any suggestions
                                          Originally posted by diuna2000 View Post
                                          Hi All
                                          this is 49 inch dump you can try
