Good day everyone.. i have the same problem. Keyboard, Touchpad, USB ports is not function.
Here is my back up..
thank you.
i tried the one post here same issue.
thank you.
both same issue.. owner said. kb nad tp usb ports is working before he attemp to reformat and when he change some settings in bios thats happen.. all disable.
is there anything i can do to this. reset switch from other model is useful. but this on has no switch like that,
Goodday sir.. This one works to my unit. thank you verry much. USB ports/ KB and TP is now working again.. thank you verry much sir.. now i dont want to go in bios settings again. haha..
again thank you sir..rionero
i dont knwo how to tag. or reply to other messegge..
Can someone help to get bios of ZED AIR IL1406.232WAGR
I have a Laptop / ZED AIR / IL.1406G.232 WAS C2W and I get a Recovery message
Your PC / Device needs to be repaired
A required device isn't connected or can't be accessed.
Error code 0xc0000001
You'll need to use recovery tools. If you don't have any installation media (like a disc or USB device), contact your PC administrator or PC / Device manufacturer.
Press the Windows key for UEFI Firmware Setti Oxc000000f and he asked me Press the Windows key for UEFI Firmware but the keyboard does not work and also the usb keyboard does not work all the ports are closed What is the solution help me I can't do anything
