Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 03-13-2019, 04:56 PM   #1
Spork Schivago
Your Awesomeness
City & State: Corning, New York
My Country: United States of America
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Help finding a suitable replacement FCHS30A08
Hello Everyone!
I need a replacement FCHS30A08 Schottky Barrier Diode (common cathode) but I do not want to order over-seas and am having trouble locating one in the states.
Could someone recommend a suitable replacement for digikey or mouser?
I have attached the datasheet for the component. It's an 80V 30A Schottky Barrier Diode.
Thanks!
__________________
-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
Spork Schivago is offline   Reply With Quote
Old 03-13-2019, 05:29 PM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Help finding a suitable replacement FCHS30A08
I did'nt check all the specs that close but, Vishay VF60100C could work
Or Taiwan Semiconductor, MBRF30200CT
That is a full isolated tab correct?
R_J is offline   Reply With Quote
Old 03-14-2019, 12:11 AM   #3
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
old pc power supply's will have suitable diodes
stj is offline   Reply With Quote
Old 03-14-2019, 02:41 PM   #4
Spork Schivago
Your Awesomeness
I see for the Vishay VF60100C, it's rated 100V, 60A. That doesn't matter? Is that just the max values?
When the original says 80V 30A, is that per 30A per diode or 30A total?
Thanks!
Old 03-14-2019, 02:42 PM   #5
Spork Schivago
Your Awesomeness
Quote:
What would I need to pay attention to from the original components datasheet?
If I find one that says common cathode and is rated at least 80V 30A, I can use it?
Thanks!
Old 03-14-2019, 04:10 PM   #6
Spork Schivago
Your Awesomeness
I also got another diode, part of the charge pump circuit I believe, which I found shorted out.
The numbers on this diode are:
Code:
LT5135
SB5150
This diode, along with two others, appear to be directly connected to the output of a transformer. I worry with this Visio there might be more wrong. Maybe I'll post a pic in the TV section.
Old 03-14-2019, 10:06 PM   #7
stj
stj's Avatar
SB5150 is the part, the S stands for schottky.
and yes, you can use a part with higher numbers - they are just the maximum values it can withstand.
Old 03-15-2019, 11:53 AM   #8
Spork Schivago
Your Awesomeness
Yup, I should have said the SB5150 is the part number. I believe the B stands for Barrier.
Old 03-15-2019, 05:14 PM   #9
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
If you use a 40A or 60A part, the forward drop might be a little lower (50mV-100mV?). OTOH, if you use a 100V part instead of 80V the forward drop might be a little higher. In a high current dual rectifier, I think common cathode is somewhere between extremely common and just about all there is. I have seen - in semi-ancient times - common anode dual ultrafasts, but they were very uncommon, higher price, and had high junction-case thermal resistance.
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 03-15-2019, 07:56 PM   #10
Spork Schivago
Your Awesomeness
Would this STPS30H100C 100 V power Schottky rectifier work for that SOT-220-3 package diode? Could I use the STPS30H100C in place of the FCHS30A08?
I believe I could...I'll just have to bend the middle leg out a bit.
Old 03-15-2019, 08:35 PM   #11
Spork Schivago
Your Awesomeness
For the SB5150, I have some HER305-T's that are 3A, 400V 50ns. Do you think I could use them, or do I really need 5 amp ones? I understand the HER305-T is going to have a higher Vf (1.1VDC). That's probably too much, isn't it? That's probably why they're using the Schottky instead of the rectifiers.
Old 03-23-2019, 11:57 AM   #12
Spork Schivago
Your Awesomeness
I used the Vishay VF60100C and that worked fine. Thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
