lcd tv TOSHIBA 32AV500P inverter board MPF3002 (PCPF0207 77C)
    I have this problem TV on the inverter module with the above code. It accepts the BL ON command voltage, but so much. Initial was defective Q50 = 2SK2837, after replacing it normally worked, then stopped with the current sound without the backlight . It is equipped with BD9766FV, FA5501A, 2904H212, RM601. The plate is quite "bushy", difficult to follow without a schematic. On somewhere I saw it would be equivalent to DPS-165GP (JQ10003), but it does not look like.
    Re: lcd tv TOSHIBA 32AV500P inverter board MPF3002 (PCPF0207 77C)
    You could probably try replacing the original inverter with a universal inverter if the CCFLs are good and if they are not good convert the CCFL backlights to LED backlights.
      It can not be, because it is not a simple inverter, and the power source (with PFC) for the inverter is also included Thanks!
        Did you check the fuse on the inverter?
          Service manuals:
          https://elektrotanya.com/showresult?...oria=&kat2=all
            ... of course, but I've been through this for a long time,Thanks.
            I also saw the service manuals on "elektrotanya.com" I'm sorry!Thanks!
