DSL Bandwidth Monitor
    Re: DSL Bandwidth Monitor
    Originally posted by Curious.George View Post
    Ah, so it came up with that "monthly total"? Are you involved in that process in any way (i.e., perhaps it reset the counter when you started taking measurements so the month ended with just those 5 days tabulated)
    Even if you ignore the actual numbers (because you have no real way of knowing if they are "exact"), it will give you a feel for whether the number make ANY sense ("Why is so much traffic being reported on this desktop system? I rarely use it for much on-line! Perhaps there's some malware using it as a relay for the Kremlin??" )
    hehehehehe..
    Yea, I figured my best option would be to let the Traffic Monitor do it's thing for a few days and then check the numbers..
    Thanx for the reply
      Originally posted by Michale32086 View Post
      I am going to put in MERLIN firmware in the ASUS on Monday and then do a recheck of the stats...
      The MERLIN firmware also has the ability to track usage via IP so that should help track down the heavy users..
      Just be aware your router is no longer being supported with updates and patches according to
      https://asuswrt.lostrealm.ca/about
      The following models are no longer officially supported:
      RT-N16
      RT-N66U
      RT-AC66U
      dd-wrt has a beta
      https://download1.dd-wrt.com/dd-wrtv...8-2018-r36410/
      I haven't used dd-wrt in a long time and switched to openwrt/lede. I just upgraded my router to 18.06 yesterday.
      --- begin sig file ---
      --- end sig file ---
