Re: Philips PLCD190P5 power supply
This power supply is a bit rare and not much information is available. the other plcd150,170,190P1 schematics are different. I am guessing that the circuit you repaired is for the standby +5, correct. If pin 11 is the control line (ON/Off) for the power supply does it change if you press the power button? It could be that the line needs to be taken low, try what budm said, place 100Ω from that pin to ground and see if the other voltages come up
This should be the path from pin 11 that controls a couple transistors that control an opto isolator, That opto should be the one that turns on the main power supply, again no schematic so its a bit of a guess.
