Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 12-24-2017, 03:00 PM   #1
bigbeark
City & State: Stratford, Ontario
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default Socket 775 pin repair
I have 2 Abit boards with socket 775 pin problems.
The first, ABIT I-45CV, has pins 12 and 13 in the 7th row, pushed in so far that the top is visible but no way of pulling them back out. I count the top of the socket as the side above the 2 cutouts for mounting the CPU. This was working, but in attempting to switch out the CPU, the Cpu flipped over and lifted a pin so it protruded above the socket. I pushed the pin in, replaced the CPU and tried to boot. Board powers up, but no boot.. When I removed the CPU this time, the pins were submerged.
The other voard is an Abit IP-35 PRO. This one has the 4th pin from the left in the second row pushed in. This one starts uo, shuts down, starts up again over and over after powering on.
Short of scrapping the boards, is there a solution?
bigbeark is offline   Reply With Quote
Old 12-25-2017, 03:46 AM   #2
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Default Re: Socket 775 pin repair
You can buy replacement sockets.
Depends on your tools/skillset.
diif is offline   Reply With Quote
Old 12-25-2017, 04:17 AM   #3
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Try using some VEEEERY fine tweezers and try picking the pin on the IP-35 Pro.
Speaking of which, I do have one as well, but never got it to work, always POST code 8.4.
__________________
Main rig:
DFI Lanparty DK P45-T2RS, Intel Xeon X5450 3.00GHz, Sapphire Radeon R7 240 2GB DDR3, 8GB DDR2-800, LiteOn DVD-RW drive, RPC 500LBL 500W (rebuilt), AVerMedia Super 009 TV tuner, Samsung HD103SI 1TB, noname black case
Dan81 is offline   Reply With Quote
Old 01-02-2018, 08:44 PM   #4
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
^ I've done this before with success on a supermicro PDSGE (Netburst Socket 775). One land was broken, and as a result my CPU was reported as an extreme edition, but the others worked good enough to run (until a heatsink mod failed and fried the northbridge, doh!). Not easy, but worth a try if you're careful. It's already dead, so what do you have to lose?
__________________
(Insert witty quote here)
ratdude747 is online now   Reply With Quote
Old 01-03-2018, 05:22 AM   #5
xelectech
retired tech
City & State: NC
My Country: USA
Line Voltage: 240/120VAC single phase 60hz
If you can get the pin standing proud (enough), then you can cut a strip of clear plastic about an inch long from a produce container and then kinda slot one edge of it along the pins and gently comb the pins, first in one direction and then 90 degrees to the first direction, gently and paying attention to what the pins are doing (easier to do with a magnifing glass).
xelectech is offline   Reply With Quote
Old 01-08-2018, 12:19 AM   #6
jtctolits
Quote:
nice idea
jtctolits is offline   Reply With Quote
Old 01-17-2018, 04:01 PM   #7
Fast Alpha
Fast Alpha's Avatar
City & State: Wales
My Country: United Kingdom
Try this out.
https://www.youtube.com/watch?v=mhOYEQ65a94
Fast Alpha is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
