Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Old 09-19-2014, 11:32 AM   #1
orientalsniper
City & State: Florida
Default ASRock Z77 Extreme 6 not powering up
Hello, I could use some help trying to fix this motherboard, so I get 3.4V in PWRSW and I also shorted the PSU to feed power to motherboard by force and I don't feel any heated part.
Could the problem be in the SIO chip or southbridge/northbridge?
UPDATE:
Only 5V in PIN9 (+5VSB) and 5V in PIN16 (PSU_ON#) of PSU connector.
orientalsniper is offline   Reply With Quote
Old 09-19-2014, 12:33 PM   #2
ReeceyBurger123
Never Give Up !
ReeceyBurger123's Avatar
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
Default Re: ASRock Z77 Extreme 6 not powering up
Lets rule out the psu first, do you have another psu to check the board with ?
ReeceyBurger123 is offline   Reply With Quote
Old 09-19-2014, 12:35 PM   #3
orientalsniper
Yeah, I've tried different PSU/processor/RAM.
Old 09-19-2014, 01:05 PM   #4
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Ok sounds like something on the board, firstly check the board all over for any shorted pins for example on the pci slots if there is nothing obvious then I will tell you what to check next.
Also check things like the usb ports and ram slots, we need to narrow this down.
Old 09-19-2014, 01:16 PM   #5
orientalsniper
Yeah, man, I already checked those: USB, SATA, Firewire, LAN, HDMI, PCI, PCIe, RAM.
Old 09-19-2014, 01:28 PM   #6
orientalsniper
Checking resistance with ATX power connector against ground:
3.3V: 265 ohms
5V: 515 ohms
12V: 3 kohms
Old 09-19-2014, 01:46 PM   #7
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Sounds like a short, firstly check the cpu vrm mosfets as they normally go first check all the mosfets for resistance just check them all and see if any of them check different from the majority of them.
Old 09-20-2014, 11:32 AM   #8
orientalsniper
Sorry, what do you mean by resistance? Gate/Source/Drain against ground?
I did test the coils near the vrm mosfets and so far it's not shorted against ground though.
Old 11-13-2014, 01:47 PM   #9
david38c63
I would start looking for bad caps that esr is too high on in the 3.3v supply and 5 volt stand by
david38c63 is offline   Reply With Quote
