I have this old c2d board which i run efi asd 3s138 and came up with with a sensor fail vp0r / pbus “sensor is reading above the high limit”
I measured voltage:
R5385 pin 1 -12.56v
R5385 pin 2 - 2.09v
Values:
R3585 is 27.4kohm
R3586 is 5.5kohm
Smc_pbus_vsense is going directly to smc ic, right?
The measured values and voltages are ok for a normal operation sensor, right?
Correct me if i'm wrong.
Broken trace to smc will result in a low reading...
Bad smc?!?
Did any of you encountered this problem?
Thanks!
Ps: does anyone have os asd for this model? Thanks!
I measured voltage:
R5385 pin 1 -12.56v
R5385 pin 2 - 2.09v
Values:
R3585 is 27.4kohm
R3586 is 5.5kohm
Bad smc?!?
Thanks!
