Have a 50" Celsus, TV powers on, screen illuminates ok, has sound, but no display, tried using menu etc and still no display.
Celsus DLED50272FHDCNTD no picture
Re: Celsus DLED50272FHDCNTD no picture
Originally posted by vinceroger69 View Poston the top of the tcon there are two small ribbon cables if you remove one end of one cable and turn tv on what do you see on the screen? reconnect that cable and try it with the second one
im running out of ideas one last test i can think of is on the tcon board you will see some round gold colored test pads with writing by the sides of them start with the ones that start with a letter v test the voltage and let us know what the pcb marking is IE VIN IN 12V VGA 1 12V ETC ETC
Originally posted by vinceroger69 View Postim running out of ideas one last test i can think of is on the tcon board you will see some round gold colored test pads with writing by the sides of them start with the ones that start with a letter v test the voltage and let us know what the pcb marking is IE VIN IN 12V VGA 1 12V ETC ETC
V12 12.31
V102 1.20
VGH 0.18
X529 2.11
V55 0.03
V12IN1 12.32
VGA1 0.08
VGA2 0.12
VGA3 0.13
VGA4 0.12
VGA5 0.13
VGA6 0.13
VGA7 0.10
VGA8 0.10
VGA9 0.01
VGA10 0.01
VGA11 0.01
VGA12 0.01
VGA13 0.01
VGA14 0.01
WP INV R602 1.04
AP0 1.07 AN0 1.32
AP1 1.07 AN1 1.34
AP2 1.10 AN2 1.28
AP3 1.11 AN3 1.28
AP4 0 AN4 0
ACP 1.19 ACN 1.16
BP0 1.07 BN0 1.34
BP1 1.07 BN1 1.33
BP2 1.09 BN2 1.29
BCP 1.21 BCN 1.17
PM5P 0
PM8N 0
PM9P 0
PM9N 0
Ducky29 has suggested the firmware has gone bad? Anyone comfirm this please?
Did you also check if any component in the TCON is hot?
Or use a hdmi and check if you have any sound. If you do have sound but no picture then TCON(most likely) /mainboard is bad.
If you don't have sound then you have a firmware problem.Last edited by ducky29; 11-26-2018, 05:39 AM.
Originally posted by ducky29 View PostDid you also check if any component in the TCON is hot?
Originally posted by Andrew F. Ali View PostThe new T-CON Bd will fix your problem. Though there is 13V on both ends of the fuse, there are on the T-CON generated voltages that are missing due to one of the ICs producing HVDD, etc is not working.
