shuttle av11 - 2700 uF - solution please
    hello
    i have a shuttle av11 mobo ( 370 soket) that have four 2700 uF 6.3 v caps , all of them leaking.
    i can not find 2700 uF 6.3 v caps.
    can i use greater UF and volt values ?, if yes what kind ?
    thanks
    try 3300
    iirc those boards are really tight so size may be a problem.
    post some pics and wev may be better able to advise.
      I 2nd.
      I always replace 2700uF caps with 3300uF caps. I have 10mm 3300uF's, so they're a direct replacement. If you can't find 10mm 3300uF's, 2200uF will likely work in place of the 2700uF's with no problems.
      Good Luck!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
