Aron bs-601 scope issue
Re: Aron bs-601 scope issue
Those voltages on the schematic are the PSU voltages and probably not enough to debug with. Not sure what else but to just trace things along since you have the other scope and have that signal generator (the probe calibration source). Else it is still possible to debug with a multimeter with the vpos pots.
I'd especially like to know what the voltages are on Q21 and Q22 as you spin the vpos pot up and down...
Originally posted by eccerr0r View PostThose voltages on the schematic are the PSU voltages and probably not enough to debug with. Not sure what else but to just trace things along since you have the other scope and have that signal generator (the probe calibration source). Else it is still possible to debug with a multimeter with the vpos pots.
Originally posted by R_J View PostIt looks like you should have -8 volts going to the center of the vert. position control, That shouuld change the bias on q29 and q30 moving the trace up or down. You say you have all the voltages but where did you check them? they may be at P3 but do they get to get to where they should. There are a number of coils in the voltage lines, make sure the voltage is on both sides of them and one is not open.
Just so i dont stuff up, witch point should i test the -8? i haveonly tested voltages at the conector
Curious as to the voltage on the collectors of both Q21 and Q22 with just one channel on, one measurement for when the vpos for that channel fully CCW and fully CW. There should be a significant difference of the voltage at that point I would guess for the two cases, ideally they should flip flop their voltages depending on which way the vpos pot is set...
I still wonder what the voltages across D10 R80 R89 D11 D14 are. Would imagine them to be something like 12V - D10 - 17V - R80 - 90V - R89 - 108V - R89 - 114V - D11 - 115V - D14 - 120V or something like that....
*sigh* lucky people with scopes that have schematics available... I wish my 20MHz scope had schematics somewhere. Not quite the same when you have schematics for a scope that has unobtanium ICs in them like the later Tektronix...Last edited by eccerr0r; 01-28-2019, 01:36 AM.
Originally posted by The_Todd View PostJust so i dont stuff up, witch point should i test the -8? i haveonly tested voltages at the conector
If you can, check the voltage on D10, (J5) then R80. also D11 and D14 they are near P2Last edited by R_J; 01-28-2019, 10:28 AM.
Good to here he has it repaired.
FROM https://www.eevblog.com/forum/repair...-amp-issue/25/
EUREKA!!!! Found the problem!!! R80 was an open line! replaced with 43k and well, now we have full range on verticalLast edited by R_J; 01-28-2019, 02:21 PM.
