Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 02-09-2019, 02:22 PM   #1
darcy
City & State: ayr
My Country: scotland
I'm a: Knowledge Seeker
Default Delta dps-300sb doesn,t start no output no led
just thought I would leave this tip for anyone with the above psu.
in my case this psu would run perfectly one day and not start the next but leave it for a few hours and it would start again.
when it wasn't working the green l.e.d. on the back of the psu remained out the fan did not turn and there was no power output.
everything inside the psu looked clean, no blown caps etc.
turned out to be C914 was under capacitance when removed and tested... replacing it fixed the psu
found more info on this website
https://itbbs.pconline.com.cn/diy/12863186.html
Darcy
darcy is offline   Reply With Quote
Old 02-09-2019, 02:46 PM   #2
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Default Re: Delta dps-300sb doesn,t start no output no led
That's CapXon for ya
__________________
Per Hansson is offline   Reply With Quote
Old 02-11-2019, 01:36 PM   #3
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
In the 5VSB circuit? Or in the PWM circuit?
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
