I have the image on the LCD but no backlight because the pin 36 (INTERFACE CONNECTION MODULE PIN CONFIGURATION - CONNECTOR LVDS) don't have the sufficient voltage
Replace it. It always break down. But test LCD panel on another laptop. When this Dport->LVDS decoder breaks down in many times it destroy every LCD that is connected to it. it cost few bucks
Sometimes the soldered RAM goes bad on asus boards.Whats your motherboard part number
I think I have the same problem with RAM, the onboard RAM and the added 4GB default ram heats up to 100 centigrade degrees when I disconnect the battery and power up the device using only the adapter. Again there were no LCD light; LCD did not power up only the power+HDD activity lights were lit.
Do I have to disable the on board RAM or I need to completely remove it by desoldering?
