Re: Ripple Current ?
It helps by preventing the arc when the switch opens from being closed with full current passing through.
When you close switch the load causes current to change much slower than opening the circuit and that helps in minimizing the arc. Charging a small 0.1uF cap isn't going to be very significant compared to powering up the load.
Technically charging the cap will make arcing worse when the switch closes but the 'hurt' there is much less than the 'help' when the switch opens.
Overall you are ahead.
