Well, most boardmakers are shifting away from the well branded and accepted manufacturers like Sanyo in favor of cheaper producers from Taiwan and China.
I would not be surprised, if those cheaper, unbranded solid caps from Taiwan will again be as problematic as those low esr elketrolytics from Taiwanese producers are in the past up to now.
The problem is always not only the knowledge, than a consistent quality in the producktion prozess.
E.g. those solid polymers are very very sensitive to trapped moisture during entcapsulation.
There is no quicktest, for that.
So if there is one producer, who missed this due to cheaper raw material, lower cleaning standards or just due to untrained and unaware workers, a long therm failure rate is unavoidavle.
I personaly would ask for Sanyo solid polymer caps, as those have proven themselve as reliable since ages.
The problem is, that you can`t be shure what caps your are get, wehn buying a new board.
E.g. Gigabyt is lately using sometimes Sanyo, and sometimes something else on the very same board.
true, lets hope thats the lessons been learnt with regards to using crap caps but I wouldn't hold my breath on it.
You would hope its a similar quality cap,
esp since they are making a big song and dance in regard to using them in their publicity machine....like how much longer they last etc
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
It appears that motherboard manufacturers are far more likely to use solid caps now. Especially 2008 and later.
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
