hi
well.. i had to temporary fix my LCD monitor (HP L1820) a few months ago..
those Elite and Lelon caps in there were all bad.
because i needed the LCD i temporary fixed it with some (partly) junk caps that were way too big connected with wires to the original cap locations.
i searched for matching and fitting miniature caps, but couldn't find any.
they were either too big to fit inside there (so i wouldn't be able to put the LCD back together) or they would fit inside there, but they didn't have matching values.
as the temporary fix worked quite good (allthough i mixed up all caps that i could find... rubys, pannys, OSTs, and g-luxons.. partly even in series) i "forgot" about searching for a real fix..
now this temporary fix seems to die on me again
the backlight randomly turns off when the LCD warms up a bit..
so i added a pc-fan on top of the LCD (where the openings are) running at 5V. seems to be enough to keep it working for a few hours..
but .,.. well.. that temporary fan-fix for the temporary cap-fix pretty much sucks..
so now i really need to find matching and fitting replacemend caps.
i went through my fav. ebay cap sellers ( PCMCS and audjade_chn ) and through big pope's cap database .. unfortunately without luck
i took a pic of the desoldered caps.
Lelon is 16V 220uF
Elite is 10V 220uF (but i cant use 6.3V caps for those, because the voltages where those Elite craps were range from about 3V to 9V.. so 6.3V isn't really an option..)
click for full size
the ruby is just for size comparison (to show how small the other ones really are)
most of those caps lost at least 1 leg while desoldering (-.-)
the legs came out of the cap itself, but not out of the pcb
Elite:
height: 5mm (without legs)
Lelon:
height: 7mm (without legs)
diameter: 7.5mm (8mm?!) -> same for elite and lelon
pin pitch: 3mm -> same for elite and lelon
any ideas..?! :/
Lelon is 16V 220uF
click for full size
Elite:
Lelon:
any ideas..?! :/
