ZHAOXIN PS-3005D DC Power Supply Not working need HELP!!
    Hi everyone I have a (ZHAOXIN PS-3005D DC Power Supply) but it is stuck on 50V which is MAX! it does not adjust to a lower voltage does anyone know where I should start looking ?
    Thanks in advance
    Re: ZHAOXIN PS-3005D DC Power Supply Not working need HELP!!
    This is a 30v max power supply.
    You need to provide more details about the problem.
    Example: when did it happen, what did you do etc etc.
    P.S: These videos might have some useful troubleshooting tips in general about this PS.
    https://www.youtube.com/watch?v=g94mpom2Ahs
    https://www.youtube.com/watch?v=Fya-4mjV4N4
    https://www.youtube.com/watch?v=_HrvuHSywms
    P.P.S: The videos linked above show the slightly higher end version with multiple selectable memories with recall function and serial port.
    However the internal design is the same.
      Check for a shorted 2N3055
        Hi Per Hansson & R_J thanks for your really quick reply
        Ok so the unit was always working fine up until i was using it to test a (Samsung 55" LED tv) with a "No backlight" issue, Instead of testing each 3.3v Led buld individually I decided to test the complete led strip calculated the leds per strip, I then set the Zhaoxin to a higher voltage probed the wrong (TP) testpoints creating continuity shorting out the unit
        since then the unit powers on, amps stay a 0a and the voltage is stuck at full 50v
        the voltage is no longer adjustable
        if there is photos or any additional info i can provide let me know
          probably the pass transistor(s) are shorted.
