Samsung UE40MU6470U. TV OK but menus hang
    Set is little over a year old with not much use in that time as it is from a holiday home.
    It starts up fine from cold and displays a good image from a sat receiver on HDMI.
    Menus etc. work fine too, but only for the first minute or so, then it stops responding to the remote (led still flashes) - whatever is on the screen just stays there. Pressing the power key eventually puts it into standby.
    As an experiment, I started it up again after cooling down and just left it running, it ran faultlessly for over 30 minutes. Tried the menu again - managed a few button presses but it froze again.
    I did get as far as displaying the software version - 1009 - (current version appears to 1221) but I am hesitant about trying an update in case it freezes during the process, and we all know what can happen then, don't we?
    Any pointers would be much appreciated.
    TIA.
    Re: Samsung UE40MU6470U. TV OK but menus hang
    Start by removing the rear cover and have a look, it might be obvious what the problem is.
      probably a cold solder joint somewhere or a bad IC on the mainboard. try to freeze the IC's with a can of air upside down. Or maybe you find a cheap replacement main board...
        Thanks for the replies guys.
        Funnily enough, this is probably the first TV I haven't taken the back off to 'have a look', because it's the most awkward one I've ever seen! No screws, just those horrible snap clips around the edge. And I mean 'snap', because one's broken already
        So I am being very careful as I don't want it to end up in a worse state than it is already. That frame is perilously close to the LCD panel. I will have another go tonight with one of those plastic phone openers.
          Main Bd issue. Perhaps a software update might help
            Don't open it, it's most probably a software issue, let update it.
              +10..Can you supply the Firmware to do the update??
