Tevion LCD 4040 main capacitor failure
    Re: Tevion LCD 4040 main capacitor failure
    maybe wait and sees what budm suggests regarding the capacitor so the old one is 220uf 450v and your replacement 220uf 450vdc
    also to save you blowing fuses have a google search and build yourself a dim bulb tester that way if there is still a short the bulb will light bright and wont blow the fuse on the psu (saves you money keep buying fuses and causing more damage)
      No old one 220uf 450vdc capas and replacement 220uf 450v capas
        https://www.badcaps.net/forum/attach...4&d=1521402936
        I do not understand about the new cap not being DC rating, it has (-) bar on one side as shown in your pictures so it is polarized cap.
          Hi my TV power supply I have change capas 220uf 450vdc which capas to good to buy https://m.ebay.co.uk/itm/MAL21594722...QAAOSwEK9UCJ9R https://m.ebay.co.uk/itm/CAP-ALU-ELE...&ul_noapp=true
            Hi Man 220UF450 volt muadil 330UF450volt ok
              So u mean to say 330uf 450v OK to use
                Yes Man scrap power supply card block capacitor Disassembly Change
                  I don't understand what you saying mate
                    Divy power supply problems ok
                      No man steal problem with power supply if can help me out
