hp dv3 dis to uma?
    hp dv3 dis to uma?
    Hi, is there any chance to convert this mobo to uma?
    hp dv3 mainboard 6050A2371701-MB-A01
    Re: hp dv3 dis to uma?
    I think its possible on this mb. Perhaps needs to move /change board id resistor near kbc ite8502. dont have schematics, so cant be sure. I did it on dm4 mobo which is very similar to yours. give it a try.
      Thanks for your answer.
      I have forced a low level on pin 2 of R166, (MB_ID2, pin119 of ITE) but nothing changes.
      I have also disconnected coil L6.
      Can you point me any other advice?
      Here is the schematic:
        I'm still trying to convert this motherboard from discrete graphics to uma graphics, but with any luck.
        I have been tried the signal DGPU_PWR_EN, but same results. (on other motherboards do the trick)
        Nobody has experience converting this almost identical mobos:
        ST133i 6050A2314301-MB-AX1 HP CQ32
        and 6050A2371701-MB-A01
        Perhaps with a new bios?
        Thanks.
          I DO THE SAME REMOVED THE R119 AND I GO TO A NORMAL ... I WAS LUCKY.
          MY PLATE IS FROM UMA HP DM4 6050A2314301-MB-A04
            Originally posted by jeydensoft View Post
            i do the same removed the r119 and i go to a normal ... I was lucky.
            My plate is from uma hp dm4 6050a2314301-mb-a04
            only r119 you remove bro? Thanks
              Sorry, I'm wrong. It's the R166..
                good to know, thanks!
                  Please help. Where are the location of R166 on mobo 6050a2371701 mb a01? Can someone send me a picture?
                    Originally posted by balobi View Post
                    please help. Where are the location of r166 on mobo 6050a2371701 mb a01? Can someone send me a picture?
                      In my case laptop the conversion in Uma worked by removing R166 and inductor L6. My mainboard is 6050A2371701-MB-A01with i3 350M CPU
                          I succesfully converted my HP Pavilion dv3-4050et (Product no: WN975EA#AB8) to UMA. I removed resistor R166 and Inductor L6. It isn't necessary to remove heatsink or Mainboard. Just lift the faceplate (which includes Keyboard) and desolder the resistor and Inductor. Thats it.
                            Thanks to everyone for your support.
                            I 100% confirm this works superbly
                            I used this to repair my HP Pavilion DM4...
                            100% working
                              Thanks...
                                Hi Friend I removed both r166 and l6 inductor but nothing on screen .. its necesary a new bios or a new cpu my cpu is i7
                                THANKS
                                  not work remove L6 and R166
