Hi:
I am trying to bring back to live this amplifier. So far I see that main transformer doesn't receive 220V. It doesn't receive voltage because relé is not activated and doesn't close the main AC circuit to the transformer. (It's not activated because Base of transistor is not excited.......base is connected to pin2 that comes from the main PCB)
Between pin 1&3 I am getting 6.3V, which seem correct......is this the "standby" for the PCB?
Pin 2.....the one connected to base is tagged as "relay". So as soon as it gets the right voltage, the relé will receive about 21V dc....... and then all voltages should be present in the PCB. (that's my analysis that maybe is wrong).
What's the part that triggers this pin2?
Is it this part? (don't see it conneceted to the connector, but it says "relay"..)
Regards,
Francesc.
P.S: Service manual attached for reference
Regards,
Francesc.
