hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time
Samsung UE32D4010 Backlight problem, led ok
Re: UE3204010 Backlight problem, led ok
on CNM803, check the blu-on/off pin, so meter set to dcv, black probe on chassis ground, red probe on that blu-on pin, check in standby[tv plugged in but off], take note, leaving the probes where they are, power on tv, take note, does the voltage change and what is the voltage.Last edited by nomoresonys; 02-22-2023, 10:05 AM.
Originally posted by nomoresonys View Poston CNM803, check the blu-on/off pin, so meter set to dcv, black probe on chassis ground, red probe on that blu-on pin, check in standby[tv plugged in but off], take note, leaving the probes where they are, power on tv, take note, does the voltage change and what is the voltage.
4,4v power on
Re: Samsung UE32D4010 Backlight problem, led ok
Originally posted by nomoresonys View Postok, maybe try unhook cable from mainboard to panel, turn tv on, what does it do? is the optical input lit red on mainboard?
the image of the display can be seen perfectly and only that the backlight is missing
Originally posted by nomoresonys View Postcan you clarify, you mean you can see the image perfectly for 2 seconds then it goes off? if so, see if you can still see the image with a flashlight if you look really closely.
you can check mainboard for voltages, video there, not in English but shows what voltages to expect on mainboard: https://www.youtube.com/watch?v=YE_Sx573E_Y
Originally posted by nomoresonys View Postthere's probably more that go into greater detail on there but the search on youtube isn't that great, you would think it would be better since google owns youtube.Last edited by fanaticgames; 02-28-2023, 12:33 PM.
turn off any energy saving settings, like eco mode or whatever it might be called, do a simple reset, unplug tv, hold power button for 30 seconds, plug it back in and try it, did you try adjusting the brightness? wonder if a factory reset would help.
Originally posted by nomoresonys View Postturn off any energy saving settings, like eco mode or whatever it might be called, do a simple reset, unplug tv, hold power button for 30 seconds, plug it back in and try it, did you try adjusting the brightness? wonder if a factory reset would help.
Originally posted by nomoresonys View Postthis seems strange, usually when it's the backlights no mode will work properly.Last edited by fanaticgames; 03-01-2023, 03:38 AM.
well, guess its time to strip it down and investigate the backlights, just treat the panel gently, luckily it's a 32 and shouldn't be too hard to manage, can take video or pictures along the way if anything looks like it would be hard to remember how to re-assemble, need to be careful not to rip or stress the panel board connections to the screen.Last edited by nomoresonys; 03-01-2023, 08:05 AM.
