Hi folks, i have some issue with this z906. No power. So i checked inside, the AC side is fine, all working good. Then i moved to DC side, checked all the output voltage. Amp voltages seems to be fine which is 12v, 5v and so on. But the 3.3v standby voltage seems very low. So i knew thats the culprit. After further checking, a few diodes gone bad, which is shorted, and 1 IC i assume its a LDO thats supplying the standby voltage. Ive identified the faulty components but since they are SMD, im having trouble finding the codes. Can any good souls help me? Ive attached the pictures of the parts here.
Logitech Z906 Power Problem
