Nikon D810 - What is component pls 41RA sot-26
    Hello, in the I/O power board on this DLSR, this component is shorted, and I can"t find it on the web.
    It's 6 pins box with marking code 41RA (and a little date code : 11), I can't find it with 41, 41R or 41RA
    So you know what is it pls ?
    Re: Nikon D810 - What is component pls 41RA sot-26
    I still can't find it on the web, I will repost this question on the forum, on the Power Supply section, with photo.
      No repost.
      Maybe found ?
      PBSS4160V (transistor)
      This chip has a marking code 41 (but not 41RA) and according to the datasheet, 4 pins are the same one, as on the pcb (see picture).
      Could you confirm pls ?
        If that is not it, it could be similar to a IRF5800 mosfet?
          Yes it is similar, but I guess it is not equivalent. One is a transistor, and the IRF is a mosfet (so work with voltage).
          PBSS4160V is discontinued and very very hard to find. Too bad. The lone shop sell it for 15-20 euro (with shipping, tax, and other surprises). And the board have a lot of oxydation, 6 components have a bad head, cleaned but something else could be broken. So I will buy a new I/O power board for 40 euro and the DLSR will be like new.
          Thanks for the help.
            If you search for tsop-6 mosfet you may find a suitable component, there are lots to choose from.
            I do see a similar SOT-163, SI3441DV with a 41 marking code.
