Old 03-20-2023, 09:26 AM   #21
Dannyx
CertifiedAxhole
Dannyx's Avatar
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
Default Re: LG 27GL63T-B completely dead
Originally Posted by Draco82 View Post
I made measurements on hdmi. All values ​​are normal, resistance high.
I took measurements in all possible places. The L408 has a fairly low resistance of 28 Ohms. I don't know if it's supposed to be that low.
L408 reads ~700kOhms to GND on mine with IC401 removed, so it looks like there's still hope...for mine
I made another discovery after I read about it happening to another chap: I never would've even considered checking that area myself, but SMD cap C508 next to the audio jack is dead-short...I'm not sure if it's supposed to be like that, so if someone else can confirm, that would be great Cheers.
Wattevah...
Dannyx is offline   Reply With Quote
Old 03-20-2023, 02:24 PM   #22
Draco82
City & State: Frankenthal
My Country: Niemcy
There is a short on my C508 after removing the c508 there is still a short.
Draco82 is offline   Reply With Quote
Old 03-20-2023, 02:34 PM   #23
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
Could be the connector itself then - I read some people removed it entirely, though I'm not sure it's related to this particular cap - it could be a switch inside the jack. We should measure with a jack inserted, see if it changes anything. I think it's one of those combined optical/analog jacks, so maybe a DC short there is normal....won't know until someone else can confirm, or I do it myself at some point...
EDIT: just in case it helps anyone, this is the closest service manual that I was able to find. The part numbers don't all match unfortunately, so we have to go by similarities, rather than exact components...
Old 03-20-2023, 03:20 PM   #24
Draco82
My Country: Niemcy
I also removed the audio jack. It wouldn't boot without a socket either.
Old 03-20-2023, 03:23 PM   #25
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
You also read low ohms on L408, unlike mine, so at this point I'm pretty stuck as to what else you could try...
Old 03-20-2023, 03:46 PM   #26
Draco82
My Country: Niemcy
Without a schematic or a second working motherboard, I can't check anything else. I did most of the things I could do to get this motherboard to work
Old 03-21-2023, 12:15 AM   #27
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
See if the schematic I posted at #17 helps in the slightest.
Old 03-22-2023, 05:50 AM   #28
Draco82
My Country: Niemcy
I looked at this diagram and there are quite a few differences. Voltage measurements are fine, it looks like either the processor or the memory chip is dead.
I think I'll give it a rest with this monitor because the time I lose on repair is not commensurate with the value of this monitor.
Old 04-11-2023, 07:14 AM   #29
Draco82
My Country: Niemcy
I managed to buy a damaged board with a working processor. After replacing the processor, the monitor turned on. The resistance on the L408 coil must be in Kilo Ohms.
Old 04-11-2023, 07:27 AM   #30
Draco82
My Country: Niemcy
Old 04-11-2023, 08:25 AM   #31
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
Mine does, so there's still hope
Old 04-16-2023, 05:07 AM   #32
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
No dice. Mine's also dead. I replaced IC401 and restored the missing power rails, but no other reaction, not even the power LED comes on, so either the main IC died like I suspected, or there's a firmware issue
Badcaps.net Technical Forums 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
