Hi, I am troubleshooting a damaged Vizio TV (D50u-D1). Here's an overview of the troubleshooting I did with the unit when it was presented to me:
So I'm not sure what is going on. Perhaps the replacement board is also defective? Or something else is at fault? What do you suggest?
- TV powers on and back lights turn on, with normal brightness. The large Vizio logo is displayed. After a few moments (presumably when the TV is looking for inputs), the backlight turns off and the TV goes dark. No further message is displayed on the TV. Since the logo was displayed, I concluded that the power board, LED driver board, screen, LEDs and T-con board were all working fine.
- Although parts of the main board were working fine, I'm assuming that some of the other component on that board were faulty and causing it to shut down. I assumed something regarding input processor was flaky, so I ordered a replacement main board from shopJimmy.
- Before installing the new main board, I noticed that the back of that PCB had major solder/rosin residue in multiple locations. I still installed it in the TV to test it, but not only did it *not* resolve the issue, it actually made the situation worse: the backlight was no longer lighting up, and the logo was not displayed.
- I reinstalled the first board to compare the two and was able to reproduce the initial problem (back light turns on, logo is displayed, but turns off after a few seconds and then nothing)
- I re-installed the new main board, and still no backlight, no logo, nothing.
