Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
2700uF instead of 3300uF
Re: 2700uF instead of 3300uF
It usually depends on the ripple and esr of the original caps. If this is for power filtering going down in capacitance is usually not a big deal in most casesCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Satdude View PostCan I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
In terms of capacitance, 2700 uF is within 20% of 3300 uF... so OK to do.
Originally posted by stj View Postlook at the xbox threads
This is the thread itself:
https://www.badcaps.net/forum/showthread.php?t=48951
And this is the last iteration, if you want to save yourself some reading:
https://www.badcaps.net/forum/showpo...&postcount=196
If we are talking low-ESR (not ultra-low ESR like those on later PC motherboards), I do have both Chemi-Cons KYA and KYB 3300/6.3 on stock, they differ in life endurance, ESR/ripple current and size (KYA 5 mm shorter). Also do have SOME ultra-low ESR caps, or you may try polymodding it arround the CPU. Why didn't you check first?Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!
