Re: Delta TDPS-138AF Avaya no output repair
I had this type of issue with those type of capacitors on one of my Desoldering station controller board before I found it I started touching different components on the board and found a spot that was real warm and took my ESR meter and check it had 14 ohms of resistance on the power supply rail
It was not correctly controlling the temperature is why I was troubleshooting it in the first place
Plus every one in while it would just cycle the power supply
If I have this kind-a problem where it cycling a power supply I will try your little trick
“ Using this 91% IPA and feeding power trick, never gets old.”
I have one request can go into a bit of details of how you do this with out messing up the board
